Re: low oil pressure
Posted by mike mix on August 14, 2018 at 19:23:13 [URL] [DELETE] :
In Reply to: Re: low oil pressure posted by BlasterStumps on August 14, 2018 at 18:01:37:
It has a new camshaft, this engine was completely gone thru, new pistons & sleeves crank ground .010 under. I wish now I would have installed a new oil pump, I didn't because the old pump was within factory specs. I only use this tractor for mowing so it has 30 weight oil in the engine. Thanks for. the help Mike
