Re: low oil pressure
Posted by michael mix on August 16, 2018 at 11:12:50 [URL] [DELETE] :
In Reply to: Re: low oil pressure posted by Bruce(OR) on August 16, 2018 at 10:52:34:
There is no metal in the oil, this winter I plan on changing the oil pump. The reason for my question is that I've had 4 different ford tractors 2N, 8n, 2000 & the 841. all my ford tractors have had this problem, I've also noticed that ford has kept updating the oil pumps over the years to bigger pumps. This 841 had the same issue before I went thru the engine very low oil pressure at idle, the engine was badly worn. But I put everything back to spec. I can't be the only one having this problem. Thanks Mike
