Re: Setting points - 8N 6cyl Funk
Posted by Jack - Iowa on August 20, 2018 at 09:47:08 [URL] [DELETE] :
In Reply to: Setting points - 8N 6cyl Funk posted by Brent (MN) on August 19, 2018 at 21:36:41:
1958 Ford Shop Manual is as close as I can come. Use at your own discretion.
6 cyl is listed as a 223 cu. in.
Firing Order: 1-5-3-6-2-4
Initial Ignition Timing 4 B.T.D.C. ( 6 Maximum )
Dwell: 35 - 38
Gap: 0.024 - 0.026 inch
Dwell and Gap for a Loadomatic Distributor - May not be exactly correct for yours but likely close.
Good Luck,
Jack
