Re: Setting points - 8N 6cyl Funk
Posted by Jack - Iowa on August 20, 2018 at 11:34:03 [URL] [DELETE] :
In Reply to: Setting points - 8N 6cyl Funk posted by Brent (MN) on August 19, 2018 at 21:36:41:
Found a listing on line for a 1948 Ford 226
Only difference is it shows the Dwell Cam Angle: 36 degrees.
If all is in order, once you get the Gap set correctly the Dwell will fall in place. The two are directly interrelated.
