Re: Setting points - 8N 6cyl Funk
Posted by Tom on August 22, 2018 at 09:08:45 [URL] [DELETE] :
In Reply to: Setting points - 8N 6cyl Funk posted by Brent (MN) on August 19, 2018 at 21:36:41:
I agree with K.LaRue. Did you install the distributor with the timing correct? When no. 1 cylinder is at TDC on the compression stroke, the points must be about to open and the rotor pointing to the no. 1 spark plug terminal. Then if the point gap is set correctly a timing light can be used for final timing with the engine running.
