Re: Position control lever is stiff.....
Posted by DED on August 24, 2018 at 14:02:45 [URL] [DELETE] :
In Reply to: Re: Position control lever is stiff..... posted by DED on August 24, 2018 at 04:12:26:
Finished my ploughing. Not something you should do once every four years. I had messed up some of it while trying to get settings and adjustments correct. Finally got all set correctly and finished with the last looking the best! Poition control continued to work even being as stiff as it was. I have never put the draft control in horizontal position. So, I tried it, wondering how it might affect the stiffness of position control. While in draft control the plough would not lift so I put the control lever back to vertical and worked the way I always had. But, it seemed that the position control worked easier when the draft comtrol was horizontal. What does that mean? I do not know.
