Re: Back again....guy with the stiff position control lever....
Posted by HCooke on August 29, 2018 at 16:19:00 [URL] [DELETE] :
In Reply to: Re: Back again....guy with the stiff position control lever.... posted by DED on August 29, 2018 at 05:03:16:
"Question.....would it help my sticking problem if I changed out to the hydraulic fluid instead of the 80w90 I have in it? "
Maybe. I would clean out the system first.
" Is the hydraulic fluid available in most stores which carry tractor supplies?
Read the fine print. If the specs say meets Ford 134 then you are good to go.
