Re: remove hi/lo gear box
Posted by K.LaRue-VA on August 31, 2018 at 15:31:01 [URL] [DELETE] :
In Reply to: remove hi/lo gear box posted by AAm on August 29, 2018 at 16:07:37:
You will need an input shaft and housing to replace the Sherman. Noisy transmission may have been caused by not putting the correct number/size shims between the Sherman and transmission. If the preload isn't right it will still be noisy, with Sherman or straight input shaft.
