8N V8 conversion
Posted by jeff walker on August 31, 2018 at 20:06:20 [URL] [DELETE] :
Does the original 8N radiator have enough capacity to properly cool the flathead V8?
I converted an 8N with a 51 model flathead, I set the timing correctly, installed new water pumps, incorporated a coolant additive and installed an electric fan, the tractor seems to run a little hot [180-200 degrees] under a load. Any suggestions to cool engine down would be appreciated.
Jeff
