Re: Starter removal
Posted by Tim Daley(MI) on September 03, 2018 at 02:33:53 [URL] [DELETE] :
In Reply to: Re: Starter removal posted by Randy Newbie on September 02, 2018 at 18:23:27:
The block coolant drain petcock is on the LH side of engine, near the starter as shown in the picture. It is brass and is screwed into the block via an NPT (tapered pipe threads) petcock. Removing the starter is easier when this is also removed first. Drain some coolant out of the block first. Go the bottom of the radiator and you'll find another brass petcock similar to this one and place a pan/bucket underneath then open it up to drain coolant.
ENGINE BLOCK COOLANT DRAIN PETCOCK:
