Re: CYLINDER HEAD STUDS, HEX NUTS & HEX BOLTS
Posted by Tim Daley(MI) on September 09, 2018 at 15:29:55 [URL] [DELETE] :
In Reply to: Re: CYLINDER HEAD STUDS, HEX NUTS & HEX BOLTS posted by Farmer Dan on September 08, 2018 at 14:38:32:
OK - we may never use them again but always good to have the OEM part for reference. Once material gets plastically deformed, it reduces characteristics like tensile strength and can also affect torque values. Rust, dirt, oil, all contribute to inaccurate torque readings. Next time I do a block I will invest in the exact hex bolts Just8Ns sells. I've seen some snapped off studs in blocks that take a specialist to retract without boogering up the cast iron head threads. The studs are hardened steel.
