Re: Position control lever is stiff.....
Posted by DED on September 10, 2018 at 04:05:05 [URL] [DELETE] :
In Reply to: Re: Position control lever is stiff..... posted by DED on August 30, 2018 at 04:16:50:
Just a short follow up note although I expect nobody will see it. I continued to use it as I had a little bush hogging to do. After that I would not be using the hydraulics again this year. So, I attached the bush hog. I definitely found the lever to be noticeably stiffer. So stiff that I had difficulty moving it with max effort. So, the tractor comes home this week and I will start my investigation. I will re-post when I discover what the problem is. David
