Re: No voltage to coil
Posted by Tom Keith on September 12, 2018 at 09:07:04 [URL] [DELETE] :
In Reply to: Re: No voltage to coil posted by R Geiger on September 11, 2018 at 13:25:24:
Thanks all for responses. Battery checks o.k. Tractor has always run as wired so I'm not thinking that is an issue. I've cleaned and checked the ground. One of responses here says I should see voltage at "bat" post on regulator and I don't show any. I have no voltage at terminal block so ignition key not in play. I still get confused with the positive ground concept, but I have the negative battery cable going to the starter solenoid and a wire from that same post that goes to the terminal block and of course neither show voltage. So I'm wanting to ask if the "bat" post on regulator should be the source of voltage to the terminal block.
