Re: No voltage to coil
Posted by Bob in KS on September 12, 2018 at 09:36:40 [URL] [DELETE] :
In Reply to: Re: No voltage to coil posted by Tom Keith on September 12, 2018 at 09:07:04:
"I still get confused with the positive ground concept," Forget the positive ground concept for now, it has nothing to do with your problem.
"So I'm wanting to ask if the "bat" post on regulator should be the source of voltage to the terminal block" No. See explanation in my previous reply
"I have the negative battery cable going to the starter solenoid and a wire from that same post that goes to the terminal block and of course neither show voltage." Do as Bruce said, start at terminal block and trace back to battery cable connection.
Most problems are simple once you find them. Do logical and systematic troubleshooting and you will find the problem. It is a learning process
