Re: Engine oil leak on 1963 4000 ford industrial
Posted by Dean on September 16, 2018 at 10:42:06 [URL] [DELETE] :
In Reply to: Engine oil leak on 1963 4000 ford industrial posted by Will on September 15, 2018 at 22:09:18:
The governor is beneath the front cover. The front crankshaft seal is in the front cover.
If the front cover must be removed to stop a leak "near governor," the front crankshaft seal must be replaced whether leaking or not.
If, as you say, the tractor has "new ignition" and the ignition is spot on, hard starting when warm is one indication of low compression.
I would walk unless it's a steal.
Dean
