Re: Engine oil leak on 1963 4000 ford industrial
Posted by Will on September 17, 2018 at 07:15:12 [URL] [DELETE] :
In Reply to: Engine oil leak on 1963 4000 ford industrial posted by Will on September 15, 2018 at 22:09:18:
The seller of the 4000 4 cylinder tractor say it has 150 lbs of compression on all 4
How much work is there to replace front engine seal if that's what it is?
Does loader need to come off and engine removed?
Or can just the oil pan or front cover just be remover to replace front engine seal?
