Re: 1973 FORD 3000 Diesel
Posted by Ultradog MN on September 27, 2018 at 16:45:17 [URL] [DELETE] :
In Reply to: 1973 FORD 3000 Diesel posted by Poderac on September 27, 2018 at 14:37:34:
Where is it leaking?
They are pretty simple really.
One bolt that screws into the top of the injector with a copper washer above and below the banjo fitting.
Put a wrench on the bolt and see if you can tighten it a bit. If not you can buy copper washers at most hardware stores.
There's nothing under there that is going to jump out at you if you take the banjo fitting off.
If it is the rubber/plastic line just buy a piece of fuel line and a couple of pinch clamps and replace it.
