Re: Still Need Help! 2N Hydraulics
Posted by JMOR on October 01, 2018 at 19:46:40 [URL] [DELETE] :
In Reply to: Re: Still Need Help! 2N Hydraulics posted by Jack - Iowa on October 01, 2018 at 19:32:35:
Different people/different opinions. I had mine well opened up & used hands to scoop out the heavier large 'poop' deposits! Then repeatedly flushed a couple of gallons of diesel throughout using a pump up garden sprayer, catching, straining and re-spraying several times. Some say mix 3-4 gallons diesel with gallon of hyd oil and operate for some minutes. I wouldn't do that for more than perhaps 15 minutes, since diesel isn't much of a lubricant. You can likely move the spool if stuck by disconnecting the Tee from yoke and using hand to try to move it, as now you have more 'stroke' room the with the yoke connected.
