Re: ford 8 n misses
Posted by Den N Ms on October 05, 2018 at 20:03:59 [URL] [DELETE] :
In Reply to: ford 8 n misses posted by Jan Grossman on October 05, 2018 at 14:25:31:
Check the compression on all 4 cylinders with a good compression gauge,it should have 80lbs or more.It could have a stuck,bent or burnt valve causing your miss.Is the firing order correct? 1,2,4,3 CCW.
