Re: 2N Hydraulic Problem LOCATED
Posted by deanostoybox on October 06, 2018 at 09:33:02 [URL] [DELETE] :
In Reply to: Re: 2N Hydraulic Problem LOCATED posted by Tim Daley(MI) on October 06, 2018 at 09:11:56:
Copy/past from:
http://www.yesterdaystractors.com/cgi-bin/store/model_parts.cgi?SearchArea=Ford&&md=2N&cat=Hydraulic%20System&r=mcats
This Hydraulic Lift Ram Arm fit the 8N, 9N, 2N. This part will work for the 9N, 2N and early 8N but does not look like the original. This does look like the original for the Late 8N. For an early 9N, this part may require additional machining, such as grinding down the end raised portion, and/or shortening one end 1/4 inch and adjusting with shims. (Part No: 8N545B)
Just8Ns sells the part "8N only" and no listing for 9N 2N. I've worked on the hydraulics on 8Ns and hundred series, but not 9N 2N so I don't know. I suspect it would work, but some grinding may be in order. They all use the same shaft so the splines will fit.
