Re: Starter
Posted by Bruce (VA) on October 07, 2018 at 16:19:34 [URL] [DELETE] :
In Reply to: Re: Starter posted by JR in AR on October 07, 2018 at 14:51:47:
Did you check it w/ a hydrometer? Just because it has a full charge doesn't mean it's ok. A dead cell will not show u on a voltage check.
If you don't have a hydrometer , take the battery o a parts store for a load test. The most likely cause of your problem is low voltage and the most likely cause of low voltage is your battery.
