Re: 1950 8N Generator.
Posted by Jack - Iowa on November 03, 2018 at 07:36:21 [URL] [DELETE] :
In Reply to: 1950 8N Generator. posted by Dave in Wisconsin on November 02, 2018 at 19:17:10:
Dave,
How did you determine the "battery is dead"? Are you positive it is not a corroded connection or a bad cable? Start with the easy things! If you have a meter, measure that battery and the connections. If you do not have a meter, remove the cables from both battery terminals and make sure they are clean. It was running when it went in there. Find the problem before you start overhauling it.
Good Luck,
Jack (88)
