Re: Ford Jubilee 3 Point Issue
Posted by Rustyal on November 18, 2018 at 20:46:29 [URL] [DELETE] :
In Reply to: Ford Jubilee 3 Point Issue posted by Matt Buckley on November 18, 2018 at 18:01:17:
You need to have the correct fluid. But you can check for fluid leaking around the lift piston first. Look in the side cover and see if fluid is leaking down from the top. Also see if increasing the rpms helps.
