Re: Here's a new one
Posted by TOny C on November 19, 2018 at 18:55:55 [URL] [DELETE] :
In Reply to: Here's a new one posted by Roger on November 19, 2018 at 18:06:17:
Hi Roger,
Is the power supply to the ignition run through the light switch for any reason? OEM or barnyard modified?
Bypass the headlight switch and ignition switch. See what happens. If that solves the problem isolate each individually and test.
Battery condition? Good grounds? No white and green fur coats on the terminals?Battery in good shape not just surface charged to get it started and fingers crossed hoping the gen/alt will bring it up?
