Generator parts for early 9N?
Posted by JP on November 26, 2018 at 13:46:03 [URL] [DELETE] :
I have an early 1939 9N with the 2 wire 2 brush generator which used a voltage regulator, before they switched to the cut out. The generator needs brushes, brush springs, bearing, and bushing, plus one of the coils is showing continuity with the generator housing so will need to be insulated. I have not been able to find parts that say they fit this unit, only the newer one and three wire generators. Are parts available for this generator? Would I just be better off switching to the more common one wire generator and getting a cut out? Or the three wire 8N unit?
Thanks for any help.
