Re: Generator parts for early 9N?
Posted by Tim Daley(MI) on November 26, 2018 at 16:21:55 [URL] [DELETE] :
In Reply to: Generator parts for early 9N? posted by JP on November 26, 2018 at 13:46:03:
JP-
I have some new parts for the early 9N generator. You can also go with the later 2N-1000 unit and a cutout circuit to replace them with too, no need to jump into a 12V switch job if you want to keep it 6V like original. I have a newly rebuilt unit for sale -see LINK. It is the 1-Wire/3-Brush type used after the initial 2-Wire/2-Brush unit. The 9N-C and the 2N generators had a higher output -11.5 AMPS than the earlier 7 amp A and B models. If you want to change, I can make you a deal on your OEM gen and VR. I sent you an email.
