Re: 9N10000-B Generator Armature.
Posted by Tony C on December 01, 2018 at 19:56:32 [URL] [DELETE] :
In Reply to: 9N10000-B Generator Armature. posted by Del Huebner on November 30, 2018 at 13:14:55:
Only realistic hope you have is a shop which does armature and field coil rewinding. It is not going to be cheap. CHeck for a source locally, on line or Hemmings. Good luck.
If you decide to replace the generator you will be able to sell the core to a vendor or someone doing a 100 point restoration for more than the cost of a new generator.
I've been able to find shops that will rebuild very rare electrical components, 1920s Northeast and Delco starter generators, five wire Delco regulators.
Point is any electrical component can be rebuilt given enough research and money.
