Re: no spark
Posted by Tim Daley(MI) on December 14, 2018 at 10:44:39 [URL] [DELETE] :
In Reply to: Re: no spark posted by Bob in KS on December 14, 2018 at 10:05:49:
You are referring to the 2nd revision, original Induction or LOOP style AMMETER. It was released after the first 4000 9Ns that used the screw terminal type 20/20 AMMETER.The LOOP was just that. A metal loop was on the back of the gauge whereby the wire fed thru it, with no other connections required. It worked by basic electrical induction function. Accuracy was about 20%.
ORIGINAL 9N-10850-A AMMETER; 20/20 AMP, 4 SCREW TERMINAL UNIT:
OEM 30/30 AMMETER; INDUCTION/LOOP UNIT, USED AFTER S/N 9N-4000:
OEM 30/30 LOOP AMMETER & AFTERMARKET 2 SCREW TERMINAL TYPE:
