Re: Wheel weights
Posted by Tim Daley(MI) on December 21, 2018 at 13:08:58 [URL] [DELETE] :
In Reply to: Re: Wheel weights posted by Daniel Jinkens on December 21, 2018 at 09:27:13:
HiYa Dan-
Yes, as others stated, we need more information here. Wheel weights can be the 2-PC each side fronts for 16" wheels, or the 12 PC each side pie segment type with a multitude of variant aftermarket weights out there. I have a complete set of the OEM PIE WEIGHTS, 45# style. The pie weights were not introduced until the 600/800 Models. Later MPCs show they can also fit the NAA Model. In truth these pie weights will fit any 28" Ford 8-Bolt Hole wheel pattern. That being said, the 600/800 Operator Manual says not to use the HD (45#) set with the 600 model. Note the 600 is basically a slightly modified NAA Model. There was fear the rear axle couldn't handle the extra weight. that being said I've seen the weights on 8N tractors. Also can be used on 9N/2N Models but wheel plate modifications must be made. You also do not have to use all 12 segments when mounting on any tractor. Can go with 6 and stagger every other position. My email is open...
