8N hydraulic intake control valve adjustment
Posted by Travis Marshall on December 26, 2018 at 17:38:31 [URL] [DELETE] :
Iíve scoured the forums for answers to my question but havenít found any references at all.
I am rebuilding the hydraulic lift pump in my 1947 8N. Completely tore it down and cleaned every possible space. Iím a bit OCD...
The intake control valve has an adjustable stud and lock nut combination. I presume this is for adjustments perhaps necessary as the spring tension weakens over the years... Is there a published specification for the adjustments to the control valve such as length of plunger or spring length and tension values?
Thank you in advance
