Re: cold weather
Posted by Jack - Iowa on December 29, 2018 at 13:41:32 [URL] [DELETE] :
In Reply to: cold weather posted by David on December 29, 2018 at 13:05:55:
Typically they require very little choke. Both my 2N and my 860 I hold the choke out for no more than two revolutions. Generally just "flip" it out and back. Both are in sheds but no heat. SE Iowa
I never use Staybil as gasoline will easily hold one winter. If you read the instructions on the Staybil container it will tell you to drain the gasoline after a period of time. I believe it is one year.
I have ran gasoline which was 5 or 6 years old but that is not advised.
