Re: 8n lift arms
Posted by Tim Daley(MI) on December 31, 2018 at 19:39:34 [URL] [DELETE] :
In Reply to: Re: 8n lift arms posted by clair bell on December 31, 2018 at 19:22:08:
Clair-
You really need to get the essential owner/operator manuals for your N to fully understand things better. Sit on the tractor in the seat. Turn around to your RIGHT. See the leveling box crank handle fore the RH Lift Arm? That adjusts the RH arm up or down. You do not have LH crank. When using a 2-Bottom Plow, that crank will help you adjust the plow so it rides square in the furrow. That means one side is going to be off from the other. This LINK shows the leveling box crank. Forget about the document for the transport lock -you don't need that.
