Re: Paczosa
Posted by Bruce(OR) on January 09, 2019 at 11:31:27 [URL] [DELETE] :
In Reply to: Paczosa posted by Lee Paczosa on January 08, 2019 at 16:38:10:
Restoring it means going back to original.
Paint and all.
The 6V pos ground can be jump started with a 12V battery if the need arises.
Simply a case of placing the 12V pos cable on perhaps the foot peg for convenience.
Turn on the ign switch and in neutral, then briefly touch the neg cable to the starter lug only. The engine will crank immediately, the generator will turn and also start producing the voltage needed for the ignition system.
Generators do not need a reference voltage and that is why it is safer to disconnect them while the engine is running to check them. Alternators can cause issued when disconnected.
Have fun with your new toy.
Remember, if you get a second implement you need another tractor.
Njoy!
