Re: 8N Ford Tractor Lower Link
Posted by John in MIch on January 22, 2019 at 20:12:14 [URL] [DELETE] :
In Reply to: Re: 8N Ford Tractor Lower Link posted by Carlos Pizzi on January 22, 2019 at 17:48:09:
Yes there is a difference. Measure the distance between the lift arm pins in the asle trumpets and the distance between the lift points across Ford/Dearborn implements.
The difference is compensated by a slight "S" curve in the lift arm. There is also a welded loop on the arms near the implement end to place the clips to lock the arms to an implement.
I have seen bent, welded and mis-aligned lift arms on some of the tractors that I have owned. For the best results using a 3 point implement, have the right setup.
