Re: Ballast Resistor
Posted by Joihn S on January 24, 2019 at 08:58:37 [URL] [DELETE] :
In Reply to: Ballast Resistor posted by Jack - Iowa on January 24, 2019 at 08:07:04:
Thanks Jack. So how do I measure the coil voltage and what is it supposed to be? I've read values of 17,000 volts, 22,000 volts and 40,000 to 60,000 volts. Is there a good chart showing each component and what the specs are? I saw flow chart here but not much help with nothing I wanted.
John S
