Re: bad ringgear
Posted by K.LaRue-VA on January 31, 2019 at 10:25:02 [URL] [DELETE] :
In Reply to: Re: bad ringgear posted by Tim Daley(MI) on January 31, 2019 at 08:17:37:
Great suggestion! I fixed a dozen or so bad teeth on one flywheel rather than deal with splitting and replacing the ring gear. The bad spot was occasionally keeping the starter from engaging. I removed the sharp edges with a triangular shaped file, working thru the starter hole. Put starter back in with a new drive on it and haven't had any more trouble with that one.
