Re: 3 point hitch snow removal problems
Posted by steveVa on February 15, 2019 at 10:43:03 [URL] [DELETE] :
In Reply to: 3 point hitch snow removal problems posted by Jim Thorn on February 15, 2019 at 10:32:44:
If you are plowing in the forward direction, you need to shorten your top link so the top of the blade moves forward and the bottom of the blade moves back. The more you tilt the top forward the less it will dig in. You can also buy skids that are like round disk feet that will slide on the ground, but you will need mounts for them welded on the blade. Easier to tilt mor forward or put chains on it to hold it up. Goodluck.
