Re: Won't start.
Posted by Jack - Iowa on February 17, 2019 at 09:20:45 [URL] [DELETE] :
In Reply to: Re: Won't start. posted by Daniel Jinkens on February 17, 2019 at 08:32:39:
You had some other problem than the reversed battery. That alone would not fry the wiring. Tractor should start and run just fine with battery reversed but charging circuit would not work until you re-polarized the generator.
Tim gave you directions to JMOR's wiring diagrams. You need to carefully check and get it connected correctly. That before worrying about any other problem.
Good Luck
