Re: Key switch short ?
Posted by Jack - Iowa on February 18, 2019 at 09:41:14 [URL] [DELETE] :
In Reply to: Re: Key switch short ? posted by Pete Nelson on February 17, 2019 at 15:40:59:
Pete,
I forgot about the center terminal on your ballast resistor block. It is only a terminal spot and should not be a part of your problem. If you take the wires off of it, be sure and keep them all together.
Jack
