Re: Going to tackle the Lift
Posted by Tim Daley(MI) on February 20, 2019 at 04:12:13 [URL] [DELETE] :
In Reply to: Going to tackle the Lift posted by Kimberly on February 19, 2019 at 21:41:52:
You have an 8N if I remember correctly. You also best get some help as that top cover is heavy. There are u-toob videos on how-to as well. The key is to get the control inserted correctly when cover is assembled. First thing is to perform the leak-down test to verify if the cylinder is worn and leaking. You don't want to nor need to hone anything. If cylinder proves to be failing, I highly suggest you invest in a new one and forget using an old used one. That's a lot of work to go thru only to have the used one also leak. I also suggest you inspect and replace the cam follower pin if worn badly. This (see LINK) may help some...
