Re: Going to tackle the Lift
Posted by Lynn Patrick on February 20, 2019 at 14:41:39 [URL] [DELETE] :
In Reply to: Re: Going to tackle the Lift posted by Kimberly on February 20, 2019 at 12:26:12:
It is simply a fairly sturdy 1 1/4" metal strap (could be wider if wanted) 9" long w/a 1" hole in one end, a 90* bend at 3", & two 1/2" holes (to allow for mis-measuring) spaced 3 7/8" apart for the 2 seat bolts. My old block & tackle hook is about 3/4" so hooks easily into the 1" hole. When mounted w/the 1" hole in the front it tilted almost perfectly (by accident!) for lifting & replacing.
