Re: Belanger
Posted by K.LaRue-VA on February 20, 2019 at 17:47:29 [URL] [DELETE] :
In Reply to: Belanger posted by Serge on February 20, 2019 at 17:41:51:
Once the belt is loose and off the pulleys, it should barely fit between one fan blade and the fan shroud. Turning the fan as the belt comes out usually makes it easier. If your tractor has a loader with a front pump, the driveshaft for the pump will have to be removed. The exact process for that depends on how the pump was mounted. That is all aftermarket stuff.
