Re: rebuild kit
Posted by TheOldHokie on February 20, 2019 at 19:11:35 [URL] [DELETE] :
In Reply to: Re: rebuild kit posted by Jim on February 20, 2019 at 17:50:08:
The only thing in that kit that is likely to be the wrong size is the bearings. You won't know what size bearings are needed until you inspect the crankshaft to see if it has been reground in a previous rebuild or is so badly worn it needs to be the ground in your rebuild.
The pistons, rings, and sleeves are a "matched set" that are meant to work as a plug and play replacement for the OEM parts.
