Re: What have I got here?
Posted by Steve on March 08, 2019 at 20:49:08 [URL] [DELETE] :
In Reply to: Re: What have I got here? posted by TheOldHokie on March 08, 2019 at 18:25:55:
OldHokie, Thanks for the input. Have you got a recommendation for a Dual control Valve for this set up? I need one lever to lift the loader arms and the other to operate the angle cylinder. It would be be easier to re-plumb a dual valve then try to add on another single valve to the system. However if the cost of a dual valve is a lot higher, then that will be a consideration for me too. I've learned from seeing your advice to others on this Forum that your suggestions are always spot on. Your advice several years ago really helped me to re-plumb my loader with filters and a new control valve when my original control valve went belly up.
