Re: What have I got here?
Posted by SteveJ on March 09, 2019 at 10:44:12 [URL] [DELETE] :
In Reply to: Re: What have I got here? posted by TheOldHokie on March 09, 2019 at 09:26:27:
Got it, Yes the arms are single acting cylinders. It shouldn't be a problem to plumb the unused port of the valve back to the tank. I assume if I use a double action cylinder on the plow I just use both ports on one side of the valve. One to each side of the cylinder? Thanks for the link. I knew I could count on you for good advice.
