Re: 8N Control Lever
Posted by K.LaRue-VA on March 15, 2019 at 08:19:25 [URL] [DELETE] :
In Reply to: Re: 8N Control Lever posted by Kimberly on March 14, 2019 at 22:05:27:
I was timid on the first one, but figured if it got bent without breaking it should be possible to bend it back. The one you have is not bent nearly as far as mine was. A shop press provides better control in a lot less time than rigging chains and a jack. The small ball stud on the end would be easy to snap off, so don't apply pressure if that weak part is touching anything.
