Re: Need a bit of help
Posted by Kimberly on March 18, 2019 at 18:09:04 [URL] [DELETE] :
In Reply to: Re: Need a bit of help posted by Bruce (VA) on March 18, 2019 at 17:57:25:
I am trying to remove the right side running board. The two bolts in the front are rust welding so they are not coming off but just going to spin. So, I want to take the front bracket that is behind the radus arm off so that later I can grind the bolts out and replace them. However, I found no instructions for removing the radius arm. I got the front pin out and the two nuts holding the ball socket cap but now what, smack it a lot with a rubber hammer?
