Re: Rear Axle Nut
Posted by JMOR on March 24, 2019 at 17:13:25 [URL] [DELETE] :
In Reply to: Rear Axle Nut posted by Tom S. on March 24, 2019 at 17:05:43:
the seal is to the outer hub surface. I t can leak there. There isn't much that you can really call a seal between axle splines & hub splines. There is a big rubber band around axle just behind the hub, but......? I apply liberal silicone to splines before installing hub & hope for no leaks. Helps to not overfill.
