TO 30 coollant question
Posted by Bob on March 31, 2019 at 21:17:38 [URL] [DELETE] :
Bought a Ferguson TO 30 last summer, moving snow the other day when the overflow tube on the side of the radiator started spitting out coolant. I had not added any coolant to to the tractor since last summer. I was told it could be the head gasket, so I removed all four spark plugs, tested each cylinder and all cylinders were around 75 psi. Question is: would one cylinder be low because compression is going into the cooling system? Thanks for any advise. Bob E
