Re: Selinoid just clicks
Posted by mhb@ufe on April 03, 2019 at 17:30:23 [URL] [DELETE] :
In Reply to: Re: Selinoid just clicks posted by John on April 03, 2019 at 17:19:39:
Try jumping from the battery to the starter and see if it turns over. Make sure the tractor is in neutral. If it doesn't the starter is bad. If it does you need to check for voltage going through the solenoid.
Mark
